1967 power steering pump - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1580
    ??all wrench & while applying a brake force in pulley groove, torque by.
    What kind of wrench should be used, or socket & ratchet?
    What is the correct torque?
    Should lock-tite BLUE be used on the pulley retaining nut?
    Don
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1967 power steering pump
    allen wrench. insert it into the pump shaft. that being said, I simply use a 1/2" drive impact wrench to tighten the nut.loctite a good idea. mike
      Mike-----
      I'm not aware that these power steering pump shafts had provisions for an allen wrench. Have I missed something?
        Originally posted by Donald Olson (17357)
        In the AIM:
        On UPC N40, Sheet A5,
        under the “Mandatory Assembly Instructions”
        Step 4
        Use a ??all wrench & while applying a brake force in pulley groove, torque by.
        Don
        Don------
        Which pulley do you have? Is it a stamped steel or cast iron?
        • Mike M.
          • May 31, 1974
          • 8365
          Joe: u are correct, senility catching up with me. I was thinking of removing alternator pulleys. the impact wrench trick works though. regards, mike
          • Donald O.
            • May 31, 1990
            • 1580
            Don------
              Joe,
              Right now, neither.
              I am trying to do the installation in my head first.
              My right shoulder is so eff upped that I am faced with the option of either adding power steering or not driving the 67. I would rather add the p/s than just park it in the garage.
              I’m going through my books and service manuals before I drop a g-note on the parts.
              Which is is the correct pulley? I’m assuming it is the cast iron.
              Don
              Don------
              What engine do you have?
              • Donald O.
                • May 31, 1990
                • 1580
                Don------
                Joe,
                Since the AIM only lists one pump with pulley for all engines.....
                I have the 327 350hp, engine code HT
                Don
                  Joe,
                  Don
                  Don------
                  That's too bad (at least as far as p/s pump pulley installation is concerned); that makes it tougher. The 300 hp engine uses a stamped steel pulley, GM #3770509 that has a center fitting with flats for installing a wrench to prevent rotation of the pulley when installing the nut. This is the installation described in the AIM. The 350 hp engines uses a cast iron pulley, GM #3834720, with no such flats. The AIM is silent on installation of that pulley. It's actually the same as the aforementioned except there's no designed-in means of holding the pulley. I install the pulley onto the pump by hand, pressing it on as far as possible. Then, I put the pulley in a vice and install the nut. The shaft will not turn since there is a key in the shaft and a keyway in the pulley. Then, install the special nut and torque to 60 lb/ft. The nut, GM #3824475 is a self-locking nut and no locking compound is required.
                  The pulley and nut are no longer available from GM but are available in the reproduction/aftermarket.
                  • Donald O.
                    • May 31, 1990
                    • 1580
                    Thanks Joe.
                    Is there a difference between the pulleys other than materials, like diameter, belt groove width?
                    Don
                      Thanks Joe.
                      Don
                      Don------
                      Big differences and the two are not interchangeable. The 3770509 is 5-3/4"; the 3834720 is 6-1/2". The off-sets are completely different. The 3770509 is a standard groove pulley; the 3834720 is a deep groove pulley. However, you can use the 3770509 for your application as long as you change ALL of the other pulleys, too.
                      • Donald O.
                        • May 31, 1990
                        • 1580
                        More questions
                        Which crankshaft pulley should I use or change to? And which belt?
                        Right now its a 327 350hp L79, no P/S, no AC, no P/B, no AIR
                        with a two groove pulley for the crankshaft and the water pump.
                        Don
                          More questions
                          Don
                          Don------
                          You should have the correct crankshaft pulley now. It should be GM #3858533. As is, your crankshaft and waterpump pulleys should be connected by a captive belt. With the addition of power steering, this will be replaced by a belt which connects the crankshaft, waterpump, and power steering pump pulleys. This is a very simple addition. As a bonus, it eliminates a captive belt and replaces it with one that can be adjusted at the power steering pump.
                          The belt should be a 3/8 X 45".
