1967 Anco Wiper Blades
Re: 1967Anco Wiper Blades
According to the 6th edition of the 67 judging manual it says " In summary judges should expect to only see Trico blade holders on cars built in the 1966 calendar year. " So with that statement I would assume the answer would be no, so there would be a deduct for Anco holders and blades unless the 7th edition has change this statement. Maybe someone from the 67 team can shed some light on this subject.
Mike- Top
MikeHarry Ledgerwood
Member #2901
Current Region VII Director (2021 thru 2023)
- Top
- Top
Can't you just buy a set of current Trico wipers for a 67 corvette, and take a hit for judging like you do for a Delco battery? Current Trico plant is in Brownsville, TX. and you can buy a set at Advance or O'Reilly's per their website.- Top
John: Batteries are judged by standard deductions specifically called out by NCRS (on one of the laminated judging cards). Tires are treated that way also.
I do not think the standard deduction treatment has been applied to wipers. That leaves CDCIF (stands for Configuration, Date, Completeness, Installation and Finish) as the judging process to use.https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
Danny,
Thanks for your reply. You are correct for any car after mid-January 1967. The car I am requesting help for was produced in November 1966.
ThanksHarry Ledgerwood
Member #2901
- Top
Harry,
Correct. We expect to see Trico Made in USA for Jan and later built cars. Earlier cars we expect to see just "TRICO" on the blades and they are very tough to find so the alternative is the Ancos.- Top
Harry,
To answer your question: The Anco Blade pictured with peak design, brushed finish and two-line rubber insert was used throughout 67 Corvette production.... so the Anco blades should pass NCRS judging in both your early and late production cars. Good luck.Attached Files- Top
Harry,
To answer your question: The Anco Blade pictured with peak design, brushed finish and two-line rubber insert was used throughout 67 Corvette production.... so the Anco blades should pass NCRS judging in both your early and late production cars. Good luck.- Top
