crank spring - NCRS Discussion Boards
crank spring
  • Carmelo P.
    • May 9, 2016
    • 50
    crank spring
    Can someone tell me the function of the side window regulator crank spring? How would i know if its working?
    Replaced the large spring
    but the window still falls down 1 inch when closed..thanks...
  • Richard G.
    • July 31, 1984
    • 1715
    Re: crank spring
    Carmelo;
    The spring balances the window weight so the window crank rotates easier.
    Likely you are missing some teeth on the gear.
    A close inspection should identify the issue.
    Rick
    • Carmelo P.
      • May 9, 2016
      • 50
      Re: crank spring
      Will check the crank teeth, large gear looks good. Any source for the crank gear?.
      • Edward D.
        • October 25, 2014
        • 206
        Re: crank spring
        Its generally easier and cheaper to just replace the entire regulator assy. You can find good used ones on eBay fairly cheap. Gear repair parts are available though from several parts vendors.
