Hi All,
G'Day from Aus. Its been a while since i last posted something on the forum but have continued to enjoy the great information shared by everyone.
I've been doing some updating in the engine bay and wanted to check a couple of things around pulley's, Water pump and Power Steering pump.
Ive attached some photo's to show the current set up with the radiator and shroud out, as this will be the last thing i refit. The water pump. pulley and idler are only test fitted for the moment just to get a feel everything will work. My questions are:
1. Whilst the bottom mounting bolt and spacer are not fitted does the new idler pulley look to be in the correct place? It seems to be very close to the power steering pump pulley, within millimetres
2. I believe the water pump pulley is the correct on for my car (July 69 L68) but when i pulled it apart it had a spacer fitted (see attached pic). is this because an aftermarket water pump was fitted? I have a refurbished correct date replacement pump i purchased form the states.
3 Does the power Steering pump look to be fitted correctly as the cap is very close to the bolt (see attached pic)?
4 I also have a correct dated replacement alternator but when i removed the aftermarket unit (Chrome) there where several washers used to space out the main mounting bolt bracket as you can see in the attached pic. Is this because the aftermarket unit is a different size? Should i remove the washers for the correct replacement part?
Sorry for all the questions but there are a few things that i'm unsure of before i refit everything. many thanks in advance for your help.
Cheers
Grahame
Cheers
Grahame
