C2 ('66) fuel line clamp photo needed - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
  • Richard G.
    • July 31, 1984
    • 1715
    Re: C2 ('66) fuel line clamp photo needed
    My only guess is the GM #140571 clip is slightly larger, or smaller, to accommodate the sleeve on the fuel line.
    Guessing it would be smaller than the other clip that just clamp the hose only.
    I can see no other reason this clip would be assigned a different part numbers.
    Note; Some of which are on the steel line only some on the line with the anti-rattle line and another the hose only.
    With no other responses I will post what the clip looked like in 63.
    Although I didn't specifically identify which clip this was.
    As you can see one of the clips has an oblong hole in the lower portion.
    I believe this would allow the same clamp to be installed in the various positions/diameters.
    This would be invisible installed.
    I am unsure if the clamp pictured (in the bottom pic.) clamp is one I had re-plated or a reproduction.
    I do remember thinking the replacements were very good, unlike many reproductions.
    The 63 used three different part numbers which may be the same as the 66.
    GM #140571 (line with sleeve)
    GM #140569 (clamps steel fuel line only)
    GM #3757102 (clamps hose only, in the rear by the tank discharge)
    Sorry I do not have any pictures of the screw.
    Hope this helps.
    • Gary B.
      • February 1, 1997
      • 6979
      Richard,
      I can't see either of your photos. Can you try attaching them again?
      Gary
      • Stephen L.
        • May 31, 1984
        • 3148
        • David B.
          • March 1, 1980
          • 687
          PN 14057 Size #8 nominal diameter 1/2 nominal bolt size 5/16 plain finish
          PN 140569 Size #6 nominal diameter 3/8 nominal bolt size 5/16 plain finish
          PN 3757102
          Screw PN 171109 Hex head tapping slotted screw 5/16-24 x 1/2 long plain finish Type C
