67 White Interior Paint
Re: 67 White Interior Paint
Hoping these images might help:
- Top
You don't say if you are looking for urethane or lacquer. If lacquer, contact TCP Global and probably send them a piece to custom match. If urethane, your local paint jobber should be able to custom match your part with their color gun or just match up a white using their color map.
At this point, codes from 67 aren't going to be much help, none of those manufactures supply lacquer any more. TCP Global does not sell flattner for their lacquer so that's another problem, you would have to see if any PPG stores still had any.- Top
I have had very good results having my jobber scan an original piece and mix paint to match. I can't remember which PPG product I used but I have successfully spot painted interior scratches with an airbrush using it.You don't say if you are looking for urethane or lacquer. If lacquer, contact TCP Global and probably send them a piece to custom match. If urethane, your local paint jobber should be able to custom match your part with their color gun or just match up a white using their color map.
At this point, codes from 67 aren't going to be much help, none of those manufactures supply lacquer any more. TCP Global does not sell flattner for their lacquer so that's another problem, you would have to see if any PPG stores still had any.Dick Whittington- Top
- Top
Thanks Dick,
I wish I had some good trim pieces. Someone dissembled this car 25-30 years ago and the paint is long faded and deteriorated beyond recovery.
Appreciate the reply, Tom- Top
