I'm curious about something having had no personal experience with it.
As many know, 1968-74 big blocks with C-60 used an idler pulley in the engine pulley system. Without C-60 these applications used a captive belt between the balancer and water pump pulleys. With C-60, a longer belt was used with an added idler pulley assembly.
There were two different designs used over the period, though. For 1968 only, the idler pulley assembly included a standard grooved pulley. The belt ran through the grooved pulley and OUTWARD tension was adjusted at the idler pulley bracket.
For 1969-74, things changed. The idler pulley bracket changed to a different configuration and, more significantly, the pulley changed. The pulley now included no groove. In addition, the belt routing changed. Instead of the "V" section of the belt riding in the pulley, the rear of the belt rode on the pulley, with the pulley exerting INWARD pressure on the belt. The inward pressure was adjusted at the idler pulley bracket. However, the width of the pulley and the width of the rear of the belt were about the same so there was little tolerance for any lateral displacement of the belt and no mechanism for insuring the lateral placement of the belt.
The 69-74 configuration seems very "unstable" to me. I've wondered for years why the change was made from the 1968 configuration to the 1969-74 configuration. I'm sure there was a good reason for it but I've never figured it out.
My question is this: for those that have lived with the 69-74 configuration for awhile, have they ever experienced a circumstance in which the belt became displaced from the pulley?
