1963 Dash Pad and Vinyl Replacement - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 398
    I viewed a few older posts regarding dash pad and cover replacement after the shop recommended replacing instead of trying to re-dye. While the dash is not cracked, it is severely faded and has been exposed to lots of Texas sun during it's life. The vinyl "skin" at the bottom area of the center section is peeling and needs repair. Shop is saying it may very well cost more to prep and re-dye (without guaranteed results) that to replace. I will try to send photos after my trip to the shop tomorrow or Friday.
    Any thoughts/suggestions are appreciated as always.
    Fred
  • Douglas L.
    • August 31, 2003
    • 299
    Re: 1963 Dash Pad and Vinyl Replacement
    Fred - What is the color of the interior?
    • Loren L.
      • April 30, 1976
      • 4104
      What is "peeling"? iT'S VINYL! It's either there or it's NOT! It's only "peeling" if it's been dyed before. Get to another shop without delay.
      • Frank D.
        • December 27, 2007
        • 2703
        Peeling is prob the vinyl lifting from adhesive failure....on my red 63 coupe interior I pulled the whole dash frame and put new Corvette America pads on it myself.... Once the frame is out installing the pads is just a matter of dealing with the butterfly clips. I re-dyed the interior with Corvette America's 63/64 red interior dye....and that worked wonderfully.
        • Mike D.
          • July 31, 1996
          • 303
          Get a sample of the replacement pad before making a decision. Original grain is usually smoother than the reproduction pads. Judges notice the obvious difference in grain on the judging field if this is the direction you are headed in. Same with the seat backs.
          Mike Doty
          Intermountain Chapter Judging Chairman
          Region VIII Director
          • Frederick H.
            • August 31, 1983
            • 398
            Sorry - bad description. It is cracking where it curves at the bottom.
            • Frederick H.
              • August 31, 1983
              • 398
              It is a very faded red.
              • Frederick H.
                • August 31, 1983
                • 398
                Good call - thanks Mike.
                • Frederick H.
                  • August 31, 1983
                  • 398
                  Thanks for the info Frank. The car is in the shop so any labor will be on them (unfortunately I do not have the time nor the help to take on the heavy lifting of finishing the car - which is about everything - doors, engine and trans install, wiring harness) . Good to know about the Corvette America pads and dye.
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    I understand, not everybody has the time or skills to tackle the tougher jobs, I farm things out at times.....my 63 dash pads were shot with cracked vinyl and bursting foam so there was no question about "saving" much...but the result worked out fine and I'd have to look but I lost very little points on that area during judging. Now, door panels on a 63 coupe are a different ball game....any of the repros I've seen are pretty sorry as far as fitment....
                    • Frederick H.
                      • August 31, 1983
                      • 398
                      Yep - my dash is in excellent condition, just faded. The shop is concerned that a re-dye may not last due to the exposure and age. I have also heard about the door panels so I had planned to restore my originals - they are in good shape as well.
                      Thanks again for the help.
                      • Frederick H.
                        • August 31, 1983
                        • 398
                        Well, the driver's side dash has been sprayed and it looks great but seems a little lighter red than it should be. The more noticeable part is that the finish seems dull. I ordered through Corvette America but the invoice shows Top Flight Automotive as the vendor. Anyone else have this experience? Remedy? (I did compare the original grain on my dash vs the swatch of the replacement material Corvette America sent and theirs is definitely more grainy).
                        Fred
