I have a problem with the choke not opening wide enough after the engine is started. It idles rough, and unles I manually open the choke (or rev engine for 5 to 10 seconds at about 1500 to 2000 rpm), it wil idle down and stall. I think the idle vacuum is too low, and doesn't open the choke enough. I have no idea what the vacuum should be. I put a vacuum gage on the vacuum line, and after starting, while idling (either rough or smooth after warm up) it reads between 12 and 13 in hg. What should it read????
Thanks.
Thanks.
