I need to replace the battery in my 66 Vette. The recent cold weather in Scottsdale has taken its toll. I have a 66 327/350 L79 with factory air and need to replace the battery. Does anyone have a recommendation as to how high the amps should be without damaging the electrical system? In recent years starting the engine after it has heated up has been really sluggish. I am thinking I need 600+ in amps. Also does anyone have a recommendation as to the type or name of a good high amp battery, maintenance or maintenance free? Where in the Phoenix metro is a good place to purchase a battery that will be the right size to slide in the wheel well opening? Not sure I want to go the Walmart.
Battery replacement - amps for better starting
Re: Battery replacement - amps for better starting
First check that all connections in the starting and charging systems are clean and tight. Then check the battery: static voltage (12.6v), voltage while running (13.5 - 14.5v), and voltage while cranking (9.5v or more). Here's a decent article: https://www.aa1car.com/library/2004/ic120434.htm
Low cranking voltage may indicate a weak battery or a starting system that's drawing too much current. A shop can test the amp load while cranking. Over 250-300 amps may indicate a bad starter or maybe an engine that's difficult to spin. Excessive initial timing is a common cause of high current draw while cranking.
A standard 500CCA battery should be adequate for this car.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
I just bought a Delco 78VPGHR Battery with 800 CCA for my '72 LT1 w/ac. I live just South of Chandler, AZ. Great Battery. A high specified CCA battery won't destroy or harm a starter motor. The CCA is the available amount of current the battery can put out at 0 degrees F.- Top
Jerry------
An ACDelco 78 VPGHR is a side terminal battery as used for all L1969-82 Corvettes. I don't think that a group 24, top terminal, VPGHR battery is available anymore for C2 Corvettes. A 24-5YR is available, though, and this battery has 525 CCA. That's plenty for the application and what I would use.In Appreciation of John Hinckley- Top
Joe, you are absolutely correct my battery is a side mount terminal battery.
A Delco battery is a great battery, but I am not sure how it will fare at judging meets. The new Delco battery I purchased replaced a 9-year-old Battery I got from Restoration Battery. It served me well both in performance and at judging meets several years ago.
To the OP: I got my new Delco replacement battery from Factory Motor Parts, 6849 East Main St, Mesa, AZ 85207. Their telephone # is 480-921-9292. They are a very large national auto parts distribution company.- Top
Jerry------
A Delco replacement battery will garner more judging points than any other branded replacement battery.In Appreciation of John Hinckley- Top
The amp draw is dependent on the load not the battery, up to the batteries discharging capacity.
This could caused by the battery and a lot of other things. The starter is one of the items as Wayne pointed out.
It could easily be defective cables or connections. If you don't know how to do a voltage drop test there is lots of information on the internet one how to perform this test. It is simple enough all you need is a volt meter and someone to crank the Corvette while you take the measurements.
You can throw a lot of money at this or complete the proper testing and only replace the needed parts.
Don't forget to test both the positive and negative cables.
Rick- Top
Thanks Joe. I purchased a Delco 24 PG with 700 CCA for about $115. I installed it and wow it made a difference in the cranking and did not have the sluggish problem after it heated up. Thanks for the help.- Top
My neighbor's '77 Coupe needs a new battery, which is a Group 78. I was at Walmart yesterday and they had a one-year free replacement Group 78 for $49.88. A higher warranty version was just under a hundred bucks, and I think both were rated at 500 cca.
Both are Johnson Controls manufactured, and I believe the only difference is the warranty, so the hundred dollar version just has a built-in extended warranty.
Duke- Top
- Top
Check out this website: https://www.batterycentralmall.com/B...-Corvette.html- Top
