Hello,
I am attaching my 65 Coupe instrument cluster wiring harness to the instrument cluster before installing the whole works in the car at once.
I cannot get both of the clips that hold the harness to the dash housing to insert in their holes. There does not seem to be enough distance between the clips. Harness is from Lectric Limited for a 65 with backup lights.
When I look at the aim it shows that the lamps for the brake and headlamp alarms and the high beam indicater lamp are all mounded down on the main body of the cluster and this looks like it would allow the harness to fit. However my cluster has the lamps all mounted on the metal piece that the tach and speedometer are bolted to so they and the top panel lamps are directly in the way.
I will call Lectric Limeted Tomorrow but wanted to make sure I wasnt missing something simple in the mean time.
If anyone could post a picture of the backside of their cluster with the harness connected I would greatly appreciate it!
Thanks in advance!
Bill
Thanks in advance!
Bill
