1963 BW T10 Slip Yoke - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5258
    Happy Holidays,
    Any one have a few pictures of a 63 T10 16 spline slip yoke.
  • Harry S.
    • July 31, 2002
    • 5258
    1963 Transmission Slip Yoke
    Well, I need to replace the yoke on my April built 63 with a BW T10. Best I can determine the part number is 3818916. I also determined that they are impossible to find.
    Anyway, anyone have a recommendation for a source. I'd assume LIC and Paragon and others have the same supplier, then it just boils down to price. If not does anyone know of a US supplier?
    Happy Holidays
      Re: 1963 Transmission Slip Yoke
      Happy Holidays
      Harry------
      The part number for the 1963 BW T-10 yoke was GM #3818916. It was discontinued without supercession in May, 1975. So, it's not surprising that NOS examples are hard to find.
      • Richard G.
        • July 31, 1984
        • 1715
        Re: 1963 BW T10 Slip Yoke
        Would this one work for you Harry?
        Its on Ebay, but not under any application.
        16 Spline 1310 Series GM Early Transmission Slip
        The vendor has 8 of them.
        Here is another one for $110.
        Here is another $99 and free shipping;
        https://www.ebay.com/itm/Transmission-Yoke-Powerglide-Automatic-Manual-2-3-1331-GM-1956-1962-cars/132812987136?hash=item1eec455b00:g:s9QAAOSwxB5bvBt T
        Above parts are Not GM but might function just fine while you look for another.
        I have a GM one in the tail shaft of a 60 Corvette 3 Speed.
        If you are interested in it PM me.
        Rick
        • Harry S.
          • July 31, 2002
          • 5258
          Thanks, but that;s for a C1
          Harry
          • Harry S.
            • July 31, 2002
            • 5258
            I found a 63 16 spline slip yoke. There is no plug in the end. I've got conflicting input. The driveshaft shop says it can't be replaced. The seller, whom I trust, says it's a simple swap out of the plug in the existing yoke.
            Thoughts please.
            • Timothy B.
              • April 30, 1983
              • 5177
              Harry,
              You will have to excuse me but what plug?
                • Harry S.
                  • July 31, 2002
                  • 5258
                  Yea, found an NOS one, still in the box, on an obscure muscle car website. I ordered it, they called and verified they had it and will ship it tomorrow. Very good price, lower than expected.
                  https://autopartsobsolete.com/
                  • Richard G.
                    • July 31, 1984
                    • 1715
                    I went and got a picture of the yolk from my 63.
                    The plug is the one in the middle of the spline at the end closest to the u-joint.
                    It is barely visible in the picture.
                    I have replaced others (not 63 Corvette) and I just purchased a soft plug and drove in in with a little Loctite to keep it there.
                    The yolk should be missing a spline. This is so the air between the end of the output shaft and the back of the yolk has somewhere to go.
                    The cap is there so GM wasn't broaching splines into a blind hole.
                    I also looked at the 60's Corvette yolk. It's way different as the joints are pressed in not bolted.
                    I would like to know it there are other differences between the 63 yolk and the other C2's besides the spline count.
                    Would I be correct if I made the assumption this was changed when GM went to the Muncie in late 63.
                      Richard------
                      ALL 1963-82 Corvettes used saddle-type u-joint yokes for both the transmission and differential yokes. 1963-67 as well as 1968-70 with manual trans used 1310 series u-joints with u-bolts/nuts for u-joint retention. For these, 1964-70 transmission yokes were 26 spline.
                      1968-70 with M-40 as well as all 1971-82 used yokes designed for 1330 series u-joints. These yokes have a wider saddle than the above but with the same size trunnions. However, for these yokes, the u-joints are retained by straps with hex bolts. These transmission yokes were 32 spline.
                      As far as passenger cars go, I know of no non-Corvette use for the saddle-type yokes. However, it's possible they were used for some truck applications. About trucks, I know not.
                      • David B.
                        • March 1, 1980
                        • 687
                        In the category of useless information: The "plug" PN 3714559 was originally designed 7-19-54 crimped into part #3818917 with the following description: "To withstand direct hydraulic pressure of 900 lbs. per sq. in. without loosening or leaking SAE #30 crankcase oil"
