63 power brake conversion
Re: 63 power brake conversion
I understand from this thread that the "flag" that is bolted to the brake pedal arm is only on cars with PB. If that is correct then what does the stop light switch plunger make contact with on non power brake cars?Ed- Top
Ed,
It touches the forward edge of the pedal arm itself to activate.- Top
Harry, do you have a picture of the rivet. Most of the time I have seen aluminum rivets.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Richard - thanks, that is what I have on my no PB 64 - I was concerned that I might be missing a part that I should have. Unfortunate that GM did not decide to put the flag on all brake pedals - it is a nice, decent size target for the switch plunger.Ed- Top
- Top
- Top
My theory is that the spring/bushing keep the pedal fully retracted when not in use so its not sitting down "riding" the brake; that's not required in a PB car because the booster isolates things and prevents that from happening, regardless of a sping (or not).- Top
For what it is worth - my '64 was built w/o PB. A PO installed a booster - but did not remove the spring. Pedal movement (both ways) felt good - it stopped on a dime. I removed the booster - had the MC restored - all back together, still stops on a dime, with just a bit more pedal effort. Those 12 inch brakes work fine - it is not that heavy of a car.Ed- Top
Edward J. Today, I sent emails showing the 1965 A O Smith original nut plate and rivets (installed on a PB coupe). I also have a repro (extra plate) without rivets to compare. The nuts are square on both the original and the reproduction version, so I am asking what the difference is that you noted above? THANKS!https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
1965 PB Nut Plate - 1.jpg. My photo is from the backside of the firewall, showing the rivet heads. Original PB 1965 A O Smith body that became #11843. I have a photo to add to this from the firewall side. NOTE: THIS IS NOT A 1963 STL EXAMPLE.
1965 PB Nut Plate firewall side - 1.jpghttps://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
Frank, and others -
What are you using to get a correct looking (and fitting) Power booster?
What I understand the 64-67 has an angle that hits the hood?
What about stamped in numbers and other details?- Top
