Trip odometer 1965 - NCRS Discussion Boards
Trip odometer 1965
  • Bruce W.
    • June 30, 1997
    • 358
    Trip odometer 1965
    Hey guys,
    Since i am going for PV on this car i need to get the trip odometer fixed. Does the whole instrument cluster have to come out?if so who can i send this to , to get it fixed? appreciate your help
    Bruce
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Trip odometer 1965
    Unfortunately yes, this is a cluster pull. Joe Ray (a member here) or Brian of Corvette Specialties Maryland (West) can do the job...
    • Joe R.
      • July 31, 1976
      • 4547
      Bruce,
      Don't want to run away business but IF the total is working and the trip is not there could be two things wrong. One and most likely the reset cable has disengaged the trip and you may be able to replace or pull it back so the trip works again. When pushing the trip knob forward to reset the trip the cable disengages the numbers before allowing you to turn the knob and reset the numbers to zero.
      The second is that the numbers themselves are stuck together and needs to be replaced. You can purchase a number set at any distributor and do the job yourself BUT you will have to remove the cluster.
      If it's the reset cable you are home free from removing the cluster to fix your problem.
      JR
      • Frank D.
        • December 27, 2007
        • 2703
        Never personally had a reset knob get stuck in permanent reset position but then I'm not the expert on the topic...
        If this is the case here then the OP dodged a bullet... I hate pulling C2 clusters...
        • Jeffrey S.
          • May 31, 1988
          • 1879
          I had the odometer repaired on my '69 prior to the Novi National and the trip odometer didn't work. I discovered that after resetting it, if I didn't make sure the reset knob was pulled down all the way, it would not work. I jiggled it and pulled it down and low and behold it was working perfectly. I reset it once every year in the spring and doing this "pull down" always gets it operating properly. Here's hoping that yours is the same and it is a simple fix.
          Jeff
          • Bruce W.
            • June 30, 1997
            • 358
            Thanks Jeff i will give it a try.Don't want to pull that cluster
            Bruce
            • Bruce W.
              • June 30, 1997
              • 358
              Thanks Joe, I will give it a try
              Bruce
