1965 Brake caliper - NCRS Discussion Boards
1965 Brake caliper
  • Bruce W.
    • June 30, 1997
    • 358
    1965 Brake caliper
    Hey guys, need to replace front caliper. when looking at CC book they indicate there was an early version and later one. Vin on this car is 111922. Would this be considered an early car for this part?
    Bruce
  • John R.
    • November 1, 2005
    • 433
    Re: 1965 Brake caliper
    Hi Bruce, the C2 registry indicates you car's estimated birthday was March 2, 1965. I would not consider that early. However, let some others clarify as well.
    • John R.
      • November 1, 2005
      • 433
      Correction on the estimated dob, it's March 10, 1965.
      • Bill W.
        • November 1, 1977
        • 402
        John,
        My '66 (built around June 15 is a late car. That being said, it's calipers were the early design having the black phonic insulators retained by a screw in the center. The second design used beginning in 1967 had a taller piston and no insulator in the top of the piston. By this time (50 years after leaving St. Louis) most if not all '66s have been converted to second design calipers, probably with SS sleeves. My originals crapped out around 1970.
        You will be able to tell if yours's are 1st. or 2nd design without taking them apart. Order accordingly. Bill
          Bruce
          Bruce------
          I don't know of any "1st" and "2nd" design for calipers for the 1965 model year. All 1965-E67 were equipped with "1st" design calipers. L67 and later were "2nd" design.
          • John R.
            • November 1, 2005
            • 433
            I wonder what the CC book actually states, per the original post? Seems to infer some difference between early and late cars.
            • Gary C.
              • April 1, 1998
              • 375
              I think this is correct;
                First Design Second Design Third Design
                Year 1965 – 1966 &
                very early 67’s
                1967 – 1971 &
                very early 72
                1972 - 1982
                Front Inner 5465954 5452270 5473795
                Front outer 5465952 5452273 5473796
                Rear inner 5465902 5452281 5473806
                Rear outer 5465905 5452284 5473807
                Gary------
                The so-called "third design" is really not significantly different than the second design. Yes, the caliper casting numbers are different, the caliper material different, and various minor nuances of the castings different (primarily because of the different type of cast iron). However, the basic design is the same as second design. The internal parts are exactly the same as second design.
                • Bruce W.
                  • June 30, 1997
                  • 358
                  JoeThanks, I will check the numbers
                  Bruce
                    Bruce
                    Bruce------
                    Keep in mind that many 1st design calipers have been converted to 2nd design by caliper rebuilders. This involves machining out the piston guides and installing 2nd design pistons. Externally, of course, the calipers still appear as 1st design but, internally, they are 2nd design. The only way they can be externally discerned is to observe the presence or not of the 1st design piston insulator by peering down on the caliper between the pad and piston. I think this would be virtually impossible to do in a judging environment with wheels installed on the car.
                    In the early days of caliper rebuilding I think that almost all 1st design calipers going through commercial sleeving/rebuilding were converted to 2nd design. Since the 1st design are obviously the oldest of Corvette calipers, they would likely have been the first to need rebuilding and, thus, would have been included in "the early days of caliper sleeving/rebuilding". By now, I would expect that the vast majority of 1st design calipers have been converted.
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Here's the left rear outer caliper half I removed from my '65 in 1989. Paint inspection marks still evident. pistons are phenolic with center screw.
                      • Murray S.
                        • May 31, 1990
                        • 72
                        Bruce: check out this link: http://lonestarcaliper.com/p-1176-1965-1966-corvette-brake-caliper-1st-design-with-new-insulator-pistons-set.aspx
                        They provide correct 1965 calipers and are reasonably priced.
                        I used them on my 1965 coupe.
                        Murray
                        • Gary C.
                          • April 1, 1998
                          • 375
                          I think they also supply the correct bolts with castellated head.
                          • John L.
                            • February 20, 2009
                            • 186
                              Originally posted by John Lavine (50110)
                              Bruce
                              Here’s my two cents - I wouldn’t bother using the first caliper design with the troublesome insulators. Even minor corrosion between the piston and insulator or corrosion on the back of pad could crack one of the sixteen insulators. I have a ‘65 and used that first design all the way to 2007. In the early ‘70s I was at the Chevrolet dealer on a regular basis buying piston assemblies or insulator/screw. The second design was used until the end of C3 without those issues and the cars were much heavier - the first design may have been more resistant to heat transfer to brake fluids
                              John------
                              2nd design with J-56 also used insulated pistons. The insulators were much thicker than 1st design, though, and the pistons were otherwise 2nd design.
