Effective rear main oil seal in a '57 283? - NCRS Discussion Boards
  • Perry M.
    • January 1, 1977
    • 325
    #31
    Re: Conclusion Redux... wherein I am covered with shame.
    Well there you go. At least you didn't remove the pan and seal again. Way back when I was a kid I rebuilt the 340 HP motor that was in my 57 Bel Air. It leaked oil bad. I finally located the leak from behind the flywheel. The machine shop I used installed all the freeze plugs and cam bearings. What they didn't do was install the rear cam plug. I was young and this was my first rebuild. Learn from our mistakes.
    • David G.
      • May 31, 1980
      • 274
      #32
      Re: Effective rear main oil seal in a '57 283?
      I am surprised that one of us knuckleheads didn't mention that possibility. It isn't really that uncommon.
      Many years ago I overhauled (out of chassis) an 855 Cummins engine. The machine shop left one of the rear
      plugs out and I did not catch it. Big mistake. After starting, the engine would only build up a couple of pounds
      of oil pressure. Costly lesson.
