Half the instruments in the cluster of my '67 coupe don't work properly. The tach needle 'sticks' at various RPM's, the ammeter is stuck at zero, and the fuel gauge reads erratically. Although my cluster has the speed minder option, it doesn't work.
I've considered removing my cluster to have the instruments gone through and repaired, but haven't been able to nail down what this might cost. There are no repair facilities that can do this work for me locally, so a further impediment is dealing with shipping my cluster from Canada to the USA and back.
Yesterday I came across someone who has a complete '66 gauge cluster for sale. The seller sent his cluster to Auto Instruments in VA about 3 years ago to have the instruments restored and gauge faces refurbished. He subsequently went the restomod route, installing an LS motor with digital gauges, explaining why his original cluster is now for sale.
To my questions:
So, in my situation, if you had the option to spend around $500 for a complete cluster with refurbished gauges vs. sending your original cluster in for repair, what would be most cost effective? My car is not intended for NCRS judging (at this point) so my main concern is to keep the car looking stock for its year while being mindful of the cost to keep it strictly year correct.
Your thoughts?
To my questions:
- Will a '66 gauge cluster fit into a '67 without issues? What if anything would need to be changed for it to work in my '67?
- The tach in the '66 tach was converted to electronic (3 wires; coil, +/-). My car has the tach drive distributor. If I use the electric tach is it as simple as connecting the wires and removing the tach drive cable? Are there any advantages to running an electronic tach in a C2 vs. the stock cable-driven setup?
- What would be a ballpark cost to restore my original '67 dash cluster? Is the U15 speed warning indicator option complicated and expensive to restore?
Your thoughts?
