1954 fuel tank leak replacement - NCRS Discussion Boards
  • Ted K.
    • August 31, 1994
    • 337
    A couple of years ago I bought a new 1956 fuel tank from Ecklers and adapted it into my 1954 Corvette. A couple of months later I noticed a leak around the solder joint for the fuel line. After much hassel I received a new replacement tank and installed it. That was 9 months ago and now I notice seepage around the solder joint on the new tank. Hard to believe I got two defective gas tanks. Has anyone else experienced this phenomenon?
    I am thinking of trying to seal leak from the outside. Has anyone used a good sealer that really works
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: 1954 fuel tank leak replacement
    Ted,
    Can you reach the seep? With a empty tank and a inert gas such a Co2 you can solder. Normally solder will not ignite if done right, but there is always the possibility of a ember from something that could do it. I have done this before without a problem with the old wood handle soldering iron.
    Otherwise, good old JB weld seals pretty good. I have welded gas tanks that were removed, but I flushed them with water then tilted the tank so there would be a small air gap under the crack, then threw in dry ice to create Co2. Drilled a 1/8" hole where I wanted to start and when the Co2 gas came thru the hole I welded. Solder would be safe that way. Welding or soldering the 1/8 hole last made it all work. I did about a dozen tanks. Now steam cleaning won't be safe as the heat wi9ll let gas fumes come out of the seams.
    The tank was filled with water all but a cup so it was safe.
    Personally I would remove the tank and solder it using the water and dry ice with the water far enough from the place to be soldered. Tricky but it works. I have done aluminum tanks with my mig, and some large metal tanks.
    Saw 2 guys cut up a huge tank at a factory. Actually couldn't watch, but they did it. I would NEVER use their method, but they hooked a hose up to their exhaust pipe and filled the tank with exhaust!! Not for me.
    Dom
    • Ted K.
      • August 31, 1994
      • 337
      Thanks for the good information. At this time I am looking for the quick fix without removing the tank from the car. I have access to the leak as it is right where the fuel line connects. Any ideas besides JB Weld, I understand the fuel eventually softens it and starts to leak again.
      • Domenic T.
        • January 29, 2010
        • 2452
        Jb doesn't soften if properly used. Good stuff, but surface must be clean. Will do a quick fix if not permanent.
        Dom
        • Chris S.
          • January 1, 2000
          • 1064
          I buy my 54 tanks from C Central with out a leak.
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
