Hello!
Two Questions about 65 Steering column configuration.
1. in the AIM it references marks in the steering column shaft, Hub, horn contacts, steering wheel etc. Two
of them are shown on the attached picture. They are not lined up in the picture but I have corrected that. My question is this. Should the marks all be at 12 o'clock with the flat on the shaft facing straight up at the steering coupling with the wheels straight ahead? I think that is how it should be and mine is not as shown. The reason that I think it is not correct as shown is because my Bow Tie on the horn button is not horizontal with the steering and wheel straight ahead. It looks like if the mark was at 12 o'clock than the Bow Tie would be flat.
2. Second I am wandering where the plastic stud on the turn signal wire connector on bottom of the column goes. I think maybe it clips the connector onto the brake pedal bracket somewhere near the brake switch radio capacitor? Any pictures of this area on a 65 or 66 would be appreciated. I found a post for a 67 but it is a different connector.
Thanks in advance
For your help
Thanks in advance
For your help
