Hi All,
We're experiencing a whistle/ chirping nose that we cannot ID. If you get the car (70 LT1 Convert.) going 30+ MPH this noise will come. It does not stop until you're 10 MPH or less. It is not related to RPM's, drivetrain, suspension or weatherstrips as far as we could tell. Frankly it sounds like it's wind driven or air driven (air against the car as we drive?). I've even put the car in neutral and shut it off going 30 MPH it ensure it's not anything vacuum/ mechanical. This noise does not happen when the car is idling in the driveway (even at high revs). We removed the passenger side kick panel and dash. All seems as it should. Vacuumed out the birdcage behind the kick panel (clean, dry, no rust just a leaf or two). I'm guessing it's somewhere under the dash or heater box? Heater core and seals were done a couple years ago.
I've attached a video while I'm driving. You'll hear me accelerate to around 30 MPH and when I back off the gas (around 12 seconds into the video) you'll hear the noise. Any idea what this could be? Needless to say it's driving us nuts.
Thanks in advance,
Dave
Thanks in advance,
Dave
