Corvette Coupe 1966 S/N 6634 300HP PowerGlide
I'm trying to get the correct setup for the upper Kick Down Rod.
On the rear side of the Rod, I think it should be a Swivel/3711199 and a Clip/3711177.
I've seen two types of the upper Rod. One type as seen in AIM on M35/A8 and the other type
on M35/A9 (page with Linkage Adjustment Procedure). Which one is correct?
If it is the one on AIM M35/A9 I understand how to adjust the linkage.
If it is the one on AIM M35/A8 with a Stud/3904944, Clip/3904945 and Nut/3904946,
I do not understand how to adjust the linkage with the Stud running loose in
the opening in the front end of the Rod.
Can anyone help to sort this out!
Hans Ryden #868
Hans Ryden #868
