67 Bracket Identification - NCRS Discussion Boards
  • Tom E.
    • June 1, 2019
    • 448
    Can someone tell me where this bracket belongs? I think it belongs to the front windshield or dash but not certain. Working on a frame off restoration that someone else dissembled 25 years ago and nothing was bagged and tagged. I have two of them.
    Thanks Tom
  • Keith B.
    • September 15, 2014
    • 1575
    Re: 67 Bracket Identification
    yes that looks to be the one that goes on the dash for the lower windshield molding. but its missing the hole in the center of the high point for the screw
    • Peter H.
      Infrequent User
      • June 30, 1987
      • 4
      There are two of these brkts one on each end of the lower interior windshield mldg, adjacent to the vertical mldgs. The slotted hole mounts to the upper dash mounting bolt and small hole uses a phillips head self tapping screw. The hole referenced in the raised center is drilled after the lower interior moulding is in place. It appears that this a new replacement.
      • Tom D.
        • September 30, 1981
        • 2126
        Peter: We love '67s. Here's two photos showing what I found under the ends of the dash on a '65 coupe. Near the bottom of the A-pillar.
        Note the dash attachment BOLT (not in the photo) overlaps just one side (slotted) of each bracket (There are two per car, and you will find others with "fingers" that are clipped on the front edge of the dash. These are for the lower windshield garnish trim.) The remaining machine screw (shown in photos) has a philips head and a small "integrated washer". Paragon Corvette in Michigan lists these, as well as the dash holding bolt on the slotted side.
        Also note the two diff. attempts to "shoot" (install) the chrome plated garnish molding screw. Resulted in two small holes on the top of each bracket. Yours looks like the shooter missed the bracket completely. Hope you have the orig. garnish to see how this lines up. Don't be afraid to drill a new hole for the (chrome plated) trim screw. The first one shown below is the RH (pass) side.
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
        • Tom D.
          • 2126
          NCRS fyi: I attempted to edit so I could change "Peter" to "Tom" in my original reply above. The system will not let me do that because the "post is too short". Even adding ten more words, as instructed by the error message, could not get me to a finished edited re-post, so I added this.
          Not the first time for this issue.
          Michigan Chapter
          Tom Dingman
          • Tom E.
            • June 1, 2019
            • 448
            • Tom E.
              • June 1, 2019
              • 448
              • Don H.
                Moderator
                • June 16, 2009
                • 2236
                Tom
                the glitch you are describing is common to the program apparently. You can work around it when you get the "message too short" warning by hitting the "go advanced" button. Leave your edit just as it is. Then hit save changes. The edit will take. When you have a problem with a post, just drop me a note. I'll fix it for you. "NCRS" doesn't read these threads, but I do, especially yours.......
                • Tom D.
                  • 2126
                  Thanks Donnie. I did write to you via email.
                  Tom: The bracket that I referenced with "fingers" looks like these. You'll need four across the top edge of the dash. Picture is from Paragon Corvette's web site. Available at other vendors, such as CorvetteFasteners.com also.
                  My normal luck: Just one is usually lost or missing...
                  Michigan Chapter
                  Tom Dingman
                  • Tom E.
                    • June 1, 2019
                    • 448
                    Thanks Tom,
                    the clips with fingers I have and are attached to the dash, now those two square holes below the A pillar make sense,
                    appreciate the updated info
                    Tom
