Gentlemen, with regards to mid-years (63-67) just how was the engine plus transmission, if it was one complete assembly?? , lifted and dropped into/ onto the frame? Today, I was informed by a reliable source, that engine HOOKS were NOT used until the 1967 model. Getting close to my engine drop onto a bare frame (no body), and I'm not crazy about the removal of the carburator from the Aluminum intake and using the 4 bolt studs for an engine lift device to drop my assembly ( engine plus 4 speed transmission) into/onto my frame. Please comment, thank you, Jack J.
1964 coupe
Re: 1964 coupe
Here is one, not sure what year......note blackout on exhaust....Attached FilesBig Tanks In the High Mountains of New Mexico- Top
Re: 1964 coupe
Gentlemen, with regards to mid-years (63-67) just how was the engine plus transmission, if it was one complete assembly?? , lifted and dropped into/ onto the frame? Today, I was informed by a reliable source, that engine HOOKS were NOT used until the 1967 model. Getting close to my engine drop onto a bare frame (no body), and I'm not crazy about the removal of the carburator from the Aluminum intake and using the 4 bolt studs for an engine lift device to drop my assembly ( engine plus 4 speed transmission) into/onto my frame. Please comment, thank you, Jack J.- Top
Re: 1964 coupe
I installed a 396 with harmonic balancer, water pump, fuel pump, exhaust manifolds and clutch/bell housing using a 4-bolt adapter plate connected to the intake manifold. No problems at all using a 2-ton aluminum A-frame trolley hoist over the nose of the car.
The key is to be sure to use a high quality bolts (grade 8) and be sure that the bolts are installed through the lift plate and screwed as far into the intake manifold threads as possible BUT NOT BOTTOMED OUT IN THE HOLES. Use washers to bring the bolts up snug but NOT TIGHT against the lift plate. Another good idea is to be sure the weld that attaches the lifting eye to your lift plate is good with no cracks. Possibly have it (the weld) dye penetrant checked for cracks. Just my 2 cents.
James- Top
Re: 1964 coupe
Just use longer bolts to connect a chain from a water pump bolt to a bell housing bolt. Attach the hook of the lifting chain to the balance point on the chain attached to the engine. Alternatively, get a set of lifting eyes for a later engine and simply remove them after you are finished.- Top
Re: 1964 coupe
I would " never " lift or drop an engine using an adapter plate attached to an aluminum intake manifold - big block or small block. On a big block cylinders heads are drilled and tapped on the ends for either 3/8" or 7/16" bolts, use a chain with long bolts for this. On some small blocks, they may also be drilled and tapped on the ends of the cylinder heads. Also, use a chain attached at the four corners of the intake manifold with long bolts screwed into the cylinder heads.
Ray- Top
