Oil Pan Center Bolt 427/425 - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 269
    I just purchased and received timing chain cover for 427/425 being built. The there are no threads or a weld nut in center to receive bolt coming up in center attaching oil pan. On each end are weld nuts on cover to receive bolts at end. Could someone clarify?
  • Leif A.
    • August 31, 1997
    • 3607
    Re: Oil Pan Center Bolt 427/425
    Walter,
    I'm not a BB guy but this picture appears to show the weld nut you say is missing on the cover you received.
    1965-68 corvette timing chain cover BBC 427 396. FOR 7" PULLEY AND BALANCER. No dowel pin holes*PLEASE READ*Inventory of stock varies from day to day. Due to phone sales and walk in status some items might be on back order from time to time. If this
    1965 1966 Chevelle Corvette Timing Chain Cover BB 8" Balancer OE: Corvette, Chevelle, and Chevrolet Full Size 396-375hp & 396-425 hp 427-425 hp,
    What size is your harmonic balancer...7" or 8"??
    Leif
    • Keith B.
      • September 15, 2014
      • 1575
      65-66 BB only had the center bolt in timing cover and oil pan. that goes for Chevelles, and Impalas too
      • Walter R.
        • January 6, 2009
        • 269
        I have an 8" HB. I just purchased the timing chain cover from Zips. There is no weld nut just an 1/8 inch hole.
        • Leif A.
          • August 31, 1997
          • 3607
          Check this link for the 8" cover.
          https://www.heartbeatcitycamaro.com/...cer-OE-Style/#
          Leif
            Walter------
            What you have is a later cover which had the hole but no weld-nut. For 1967+ the hole was there but unused.
            • Walter R.
              • January 6, 2009
              • 269
              Do you know if the cover with weld nut is available or will I have to weld a nut on myself?
                Walter------
                It's apparently available in reproduction as seen above. As far as availability from GM, that ended a VERY long time ago.
                • Leif A.
                  • August 31, 1997
                  • 3607
                  Refer to post #2 and #5 above.
                  Leif
                  • Walter R.
                    • January 6, 2009
                    • 269
                    Thanks to everyone. I will order correct cover.
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      or you can get an original from Tracy Performance, must be 100's of them there web:
                      Detroitcorvette.com
