Survey - Early 1966 427 with Small Block Expansion Tank Bracket Factory Installed - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    Attention early 1966 427 owners!
    Production dates Sept 1965 to December 1965
    Question
    Does your 427 car have a Small Block Expansion Tank Bracket installed on the passenger inner fender?
    Background
    What then, could explain this anomaly? To arrive at a plausible explanation, it is necessary to look into Corvette body and body panel assembly methods and the overall context of'66 big block cars within historical mid-year configuration. Consider this - the '66 427 was the first midyear model that did NOT use the fender-mounted coolant tank. The St. Louis plant and the A.O. Smith body plant were ingrained in the procedure of installing the bracket on ALL mid-year Corvettes produced up until this time. When the 427 engine came along, it utilized a new radiator that did not require a separate coolant tank, and thus would have been the first model that no longer required the bracket that had been installed for years on the inner fender skirt.
    On page 193 of the Corvette Restoration & Technical
    Guide, Volume 2, Noland Adams states that clips and brackets were first installed on individual body panel pieces, then the panels were assembled into complete bodies, and finally the bodies were painted inside and out. This was the case at both St. Louis and A.O. Smith. Noland further states on page 32 that the A.O. Smith plant occasionally did a poor job implementing running changes, forcing St. Louis plant personnel to correct some items.
    Everett also makes other observations/comments:
    s oddity Did a previous owner install a bracket and coolant this a counterfeit big block because it appears that it once had a coolant tank? It is a certainty that any person counterfeiting a big block carwould have touched up the unpainted area and removed the rivets after there been a body panel replacement, which could explain the prior presence of the cooling tank
    Production changes / A.I.M. - John Hinckley
    Understanding the Assembly Manual and Running Changes
  • Vernon S.
    • November 1, 1997
    • 32
    Re: Survey - Early 1966 427 with Small Block Expansion Tank Bracket Facrory Installed
    Peter, I own a 1966 Corvette produced on Nov. 5, 1965. This is an L-36 A/C car that I have owned for almost 52 years. My car has the factory installed expansion tank bracket on the right side inner fender. I am the third owner. I knew the second owner from whom I bought the car. I subsequently met the original owner and I am confident I received this vehicle in original condition. This is a St. Louis vehicle and falls within the vin numbers you indicated.
    • Peter M.
      • February 1, 1984
      • 361
      That's great .. Your factory L36 A/Car built only 4 days ahead of mine (also factory A/C car in St Louis plant! Same anomaly expansion tank bracket bracket present!
      Would love to hear about other examples!
