'69 427 Left Valve Cover J-clip And Temp Sending Unit Wire - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 525
    Hi everyone,
    I have a '69 L68 (Jan build) with the J clip on lower rail of left valve cover as identified in the Judging Manual. But the manual doesn't describe its use. I assume it's for the temperature sending unit wire. Assuming so, how is the wire routed through the clip and then to the sending unit. For example, does it go above or below the AIR tube, enter the clip from the back or front of the clip? And it looks like from its's size iot's not made to hold the aire with the insuulation covering it but rather the bare wire. One reason I'm asking is I'm also putting on a repair wire since the original is gone so I don't have the original wire of the correct length to play with. If anyone can describe it or have a picture that'd be great.
    Jack
    Jack Ottofaro
