ok here is my situation. on aug 7th of 2019 i heard of a 1964 corvette for sale. i contacted Gail the owner. the car was bought in 1964 by her husband. it is a numbers matching car. some what. keep reading. the car had been stored in the husbands mothers garage for at least 5 years. the mother died so the car was put in the back yard at Gail's house and covered with a tarp where it sat for another 25 years. the plate on the rear of the car is a 1968 plate.
the story: the owner-Jim- bought the car in 64. he wanted a left over split window but the sales man talked him into the 64. Gail says he regretted it for years after.
now the car: is it a survivor? here is what i know about the car. (i have had my own body shop for over 40 years) it is a 64 build date Dec 6th 1963. the mileage is 37445. it is a 365 h.p. car. 4 speed posi. the numbers are matching except one head. i know he raced the car back in the day at bridgehampton race track due to all the stuff found in the car and plaque's on the glove box door. i knew some thing was up when i opened the glove box to find a rocker arm. the car was also hit in the nose at some point. the radiator is dated Dec of 65. the paint is pealing and you can see the silver under neath. who ever replaced the nose did a fantastic job. replacing it at the seams and saving the 64 fender side scoops. even under the car it is very hard to tell it has been replaced. other then it having a 66-67 plain hood. NOW the rest of the car is all original. the paint is ok but bubbling and chipping every where. the interior needs new rugs and center console. the seats are ok but the drivers side has black tape over a spot on the top back of the seat. the whole car is seized up. i am going to have a lot of fun trying to remove the brake drums. i plan on going thru the engine, trans, rear, brakes and every thing else.
i have had a few people that "know" vets look at the car, i have also talked to the ncrs leader here on the island. most say leave the car as is but then say "it's your car, do it your way".
the car does not have air or power steering/windows. i did have an air coupe in the past and on hot days the a/c was needed. i want to do a frame off restoration on the car and add a/c, power windows, and power steering. it has power brakes. also switch to a duel master, for safety, and disc in the front. with the up grades i would only do it with all gm original parts. not after market hang on a/c. i would then go down to glass and repaint the car in a base coat clear coat. as i have to go thru the engine, trans, rear, brakes, and the rugs are rotted so it needs rugs and i would have to go thru every moving part just to drive it! adding air and doing a repaint really does not add that much to the job at hand already.
i would do all i can to keep it as original as i can but i do want the air, the power steering is just bolt on items and if i have to change the wiring to do it i may as well put in power windows.
so as you can tell, i just don't know what to do. if the nose had not been replaced that would lead me to leave the car alone.
i am asking for your opinion. i know doing it "my way" will take a lot longer to do and cost a lot more. i am not in a hurry to finish it.
SO. WHAT WOULD YOU DO IF THIS WAS YOUR CAR?
