Grade 5 Nuts and Washers? - NCRS Discussion Boards
  • Rob M.
    • April 17, 2014
    • 44
    When Grade 5 bolts are specified on a C2, did Chevy always use Grade 5 nuts, plain washers and lock washers with those Grade 5 bolts? Same for Grade 8 bolts? Thanks!
  • David B.
    • March 1, 1980
    • 687
    Re: Grade 5 Nuts and Washers?
    A short version (answer) to your question.
    GM Engineering Standards specifies:
    1. "GM 286- M steel: Nuts of this material are intended primarily
    for assembly with bolts conforming to GM 280-M steel, or bolts of lesser strength".
    2 "GM 301-M steel: Nuts of this material are intended primarily
    for assembly with bolts conforming to GM 290-M or GM 300-M steel".
    3. "GM 456-M corrosion resistant steel: Nuts of this material are intended primarily
    for assembly with bolts conforming to GM 455-M".
    Since all fasteners (nuts,bolts,washers) have a part number their material make up can be verified.
    • Rob M.
      • April 17, 2014
      • 44
      Thanks for responding. These are probably dumb questions, but here goes:
      1. Is there an easy way to translate part numbers from my Assembly Manual into their material make up (GM 286-M, etc.)?
      2. Is there an easy reference guide to what Grade steel the various material make up designations correspond to (for example, does GM 280-M steel mean Grade 5)?
      Appreciate the help!
      • Michael G.
        • November 12, 2008
        • 2155
        1. No. You need the GM drawing of the fastener
        2. GM 260-M = Grade 2
        GM 280-M - Grade 5
        GM 300-M = Grade 8
        Search for any of those on google and you'll find all the info you need.
        • Rob M.
          • April 17, 2014
          • 44
          Thanks Mike!
