sealer for C1 gas tank cover - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1354
    After you replace a gas tank sending unit on a '62, what kind of sealer do you use when replacing the cover that you screw back?
    Thanks down
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: sealer for C1 gas tank cover
    William I always used 3M Strip Caulk, applied to the cover. You could also use that self-stick narrow gray foam, like for house windows, etc.
    Rich
    • Frank D.
      • December 27, 2007
      • 2703
      You want the "closed cell" foam insulation..
      • William F.
        • June 9, 2009
        • 1354
        Frank,
        You mean if I use the house window foam use closed cell foa But the caulk strips would be first choice, wouldn't they?
        • Frank D.
          • December 27, 2007
          • 2703
          Originally posted by William Ford (50517)
          Frank,
          Exactly - I used this stuff:
          https://www.amazon.com/Density-Adhes...4982818&sr=8-8
          Available in various thicknesses and lengths....and its neoprene and impervious to fuel fumes..
          • Patrick S.
            • January 1, 1988
            • 209
            I used windshield adhesive BUT I recommend you do not use it. I tried to pull up the cover and it is a real mess.
            • William F.
              • June 9, 2009
              • 1354
              Can I change just the float of the fuel tank sensor rather than the complete setup?
              • Christopher R.
                • March 31, 1975
                • 1599
                Yes. The float just snaps into the sender arm.
                • Jim D.
                  • 2882
                  As far as re-sealing the lid goes, if you don't have access to GM strip caulk, go to your local hardware store and get some "plumbers putty". It's the same thing but you'll have to make your own strips. Kind of like "Roll Your Own".
                  • Dick W.
                    • 10483
                    3M 08578 strip caulk. And you will get a total of 60' of it.
                    Dick Whittington
                    • Thomas H.
                      • August 31, 2005
                      • 1053
                      Agree - good stuff
                      Use it on my C1's for many things. Including putting on the tip of a long screwdriver to retrieve dropped nuts / bolts in hard to reach locations.
                      Tom
                      2007 Z06, Lemans Blue
