I am preparing to change out an aftermarket idler arm to an original style. I was wondering what type of seal, if any, goes between the Steering Relay Rod and the idler arm?
I have circled the area of interest in the picture below:
This is a picture of the aftermarket idler arm currently installed.
Below is a picture of the end of the replacement idler;
The hard plastic washer is all that was included with the idler arm when I received it.
Is there any other sealing part that may be missing.
I can see where this may be a high wear item if this is the only seal and, of course, no grease fitting.
I am including a couple of addition pictures.
A detailed picture of the mark in between the bolt holes.
This is the first time I have had the thumbnails work for me. I did nothing different that I could tell. Maybe the move to the new server changed something? Or it was just me? I am happy it's working.
Rick
Rick
