I have found a '63 BW Trans that states it has a first gear ratio of 2.54. I have a 340HP car so shouldn't it have a 2:20 ratio? Not a trans guy but should be able to swap out the gears, correct? The owner also states that it has the 41/4" Front Bearing Retainer. Reason for all of this is I apparently have a later trans that I will have to sell at some point but after spending $700 on the overhaul, I will use it for awhile to ensure it is mechanically sound (it should be for that amount).
The numbers on the '63 trans I am looking at are;
WC1431 (Warner/March 14th/'63 year/1st shift)
Main Case dated B 6 63 T10 D1
Tail Date 2 5 63
The other stamping shown was J247204?
Thanks in Advance,
Fred
Tail Date 2 5 63
Thanks in Advance,
Fred
) after this restoration.
