Hi, My tachometer stopped working after ~100 miles on a completely restored drivetrain. I pulled the tach cable off the distributor and found some brass shavings in the cable housing. The cable end looks perfect (and turns easily), but the drive gear hole appears to be worn to failure. I'm pretty sure the cable collar wasn't completely tight so it was slightly cocked, but is that enough to cause this kind of failure? I have a new drive gear on order already, but I'm wondering if something so simple could have caused this seemingly extreme wear...
