Where does this connector go? 1965 vert - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2395
    This 65 is new to me and I have been trying to track down stuff. See attached photo. This connector was hanging below the radio and not sure where it goes. It looks like a B/W wire and a black wire. Not radio since it works. Heater blower works.
    • 6940
    Re: Where does this connector go? 1965 vert
    John does the black wires come from the back of Radio?
    • Jim D.
      • 2882
      If it also has a red wire, which it looks like it does, it's the connector for the power antenna switch.
      • John F.
        • March 23, 2008
        • 2395
        The car has no power antenna. It has a non-powered replacement.
        • Keith B.
          • September 15, 2014
          • 1575
          it did when it was new so the wiring would be there unless someone removed it all
            • 6940
            John, if you look under the drivers rear quarter panel back splash you should see a bracket riveted to it which held the power antenna. unless that panel was replaced.
            • Jim D.
              • 2882
              That connector is part of the main wiring harness. The original power antenna's, which all 65's with the U-69 radio option had, were troublesome and many were replaced with non-original items.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                This is what the switch connector looks like. Since your power antenna is MIA, it'd be a good idea to wrap some tape around your connector. Red is always hot and if the wire terminal in your connector hits ground it could burn up the harness.
                Rich
                • John F.
                  • March 23, 2008
                  • 2395
                  No such item back there. Just the bottom of a generic/aftermarket antenna.
                  • John F.
                    • March 23, 2008
                    • 2395
                    Thank you Rich. There is no antenna switch at all. PO must have cut it out altogether.
                    • Jim D.
                      • 2882
                      This is what it would have looked like when new.
                      • John F.
                        • March 23, 2008
                        • 2395
                        Now that is nice. This is just going to be a driver, so I will leave well enough alone at this point. Thank you all for the info!
                        • James W.
                          • December 1, 1990
                          • 2640
                          [ATTACH=CONFIG]97757[/ATTACH]
                          • Jim D.
                            • 2882
                            James, It's addressed in the A.I.M U-69 sheet A-3.
                            • James W.
                              • December 1, 1990
                              • 2640
