Current 93 - 96 Service Replacement Antenna - NCRS Discussion Boards
  • Floyd B.
    • November 1, 2002
    • 1046
    Suffered an antenna mast mishap yesterday. Does anyone know if the mast on the current GM replacements (#10156160) is configured identical to the original? Is the tip the same or will it be noticeable on the judging field?
    Thanx
    -Floyd-
    "Drive it like you stole it"
  • John M.
    • May 31, 1990
    • 192
    Re: Current 93 - 96 Service Replacement Antenna
    Floyd, Sorry to hear about your antenna mishap. The service replacement tip appears very similar to a typical factory production tip. The big issue with the replacement mast is the top shaft is not magnatized and will not react to a magnet. A seasoned C4 judge should put a magnet to the top portion of the shaft. If it doesn't react to a magnet, it is a not like a typical factory production mast. I am attaching 2 photos of the black tip of a service replacement for your consideration. One photo is a raised antenna, the other is lowered. I hope this help.
      • 43193
      Thanx
      -Floyd-
      Floyd-----
      GM #10156160 is the original part number for the 1996 Corvette antenna assembly which is also SERVICE for 1993-95 (which originally used GM #10143556). I believe the tip on the currently available 10156160 is the same as original but I'm not 100% sure it's identical in every microscopic way. It is possible for small changes to occur over time within a single part number.
