I'm a new user of the forum and am currently in the process of restoring my 1965 Fuelie Coupe #5248 (Dec. '64 build). It appears that the brake/clutch pedal mounting bracket that mounts to the firewall is painted black as are the pedal arms. Is this correct? If so, is it flat or satin black. Thanks for any info.
1965 Brake/clutch pedal mounting bracket
Re: 1965 Brake/clutch pedal mounting bracket
i use semi gloss black but the upper 1/4 of each pedal arm was not painted. btw, i have 65 FI vin 5094,a white/blue vinyl coupe sold new at harry mann chevy in so cal. i got two other 65 FI's so if you need help, email me( since the 65 team leader is a bit touched). welcome to NCRS. mike mccagh- Top
TERRY, would like to get update on this car. info i have must be incorrect, or needs updateOver 80 Corvettes of fun ! Love Rochester Fuel Injection 57-65 cars. Love CORVETTE RACE CARS
Co-Founder REGISTRY OF CORVETTE RACE CARS.COM- Top
Attached are some pictures of an original set from 1965 FI coupe 6210 currently under restoration. If you need more let me know.#1.jpg#2.jpg#3.jpg#4.jpg#5.jpgI'm a new user of the forum and am currently in the process of restoring my 1965 Fuelie Coupe #5248 (Dec. '64 build). It appears that the brake/clutch pedal mounting bracket that mounts to the firewall is painted black as are the pedal arms. Is this correct? If so, is it flat or satin black. Thanks for any info.- Top
I did not realize how close your 65 FI was to mine in VIN number. Mine is # 5047.- Top
