When I restored the instrument cluster and interior of my 67, I replaced the old shabby speedometer cable and case with a Paragon repro. You wouldn't think that aftermarket an speedo cable would be a big deal; replacement cables were common long before the reproduction parts industry for old Corvettes existed. The cable didn't look as robust as the original and it was a little longer, but it is not a part that shows so having a new cable seemed good from an operational standpoint.
However, the cable is not driving the speedo. When I remove the cable at the transmission and turn it with my fingers, I can get the speedometer to move. If I rotate the rear wheels, the plastic driven gear rotates. It seems like the cable is not entering the plastic gear far enough to cause the gear to turn the cable. Have any of you seen this problem with repro cables? Did you have any solution short of putting the old cable back on?
