How exactly does the bracket be riveted to the grille on a 1966? <br />
What way do the rivets have to be installed and how exactly will the bracket be attached. Upper and lower leg? The AIM shows the lower leg clearly below the grille. Does the upper leg really go inside the visible grille? In the technical discussions I have not found a biunique answer.
