Fuel Pump Swap
Re: Fuel Pump Swap
I have a small bottle jack that just fits under the frame rail aft of the wheel and I can pump it just enough to get the tire airborne and slip a block made of wooden 2x4s screwed together to rest the frame on temporarily..while leaving the bottle jack in place with a bit of tension on it.- Top
Re: Fuel Pump Swap
I like that......I have a small bottle jack that just fits under the frame rail aft of the wheel and I can pump it just enough to get the tire airborne and slip a block made of wooden 2x4s screwed together to rest the frame on temporarily..while leaving the bottle jack in place with a bit of tension on it.
- Top
Re: Fuel Pump Swap
Ric,
I haven't seen any answers on a good source for a rebuild kit.
I ended up ordering a new pump for the current problem, but still plan to get a kit and rebuild the old pump, if we get a recommended source. Some of the Corvette Parts houses have them, but they are pretty pricey.
George- Top
Re: Fuel Pump Swap
Try ----> http://arthurgouldrebuilders.com/contact.html
I believe for $100.00 they restore, rebuild and pressure test your pump. Give them a call for current pricing. If it's still $100, not a bad deal
- Top
Re: Fuel Pump Swap
I guess you didn't see my Paragon post; I used their kits in three original 4657 pumps with no issues, I'd bet most the big vendors carry the same ones; ethanol resistant soft parts and proper diaphragm.Ric,
George
But yes you can always use one of those "less pricey" off shore Chiwanese kits with the overly stiff diaphragms that'll jam 8 psi fuel into your carbs.
Been there, done that...- Top
