Re: Transmission Speedometer Gear
Jerry
no need to run the car in gear on jack stands.
with the cable attached to the transmission, see if you can spin the cable in either direction, just make sure you simulate ALL of the bends as it would be wen installed. I’m going to guess and say you can when you shouldn’t be able to. Time for a new correct cable, you did post that your current cable is new didn’t you?
Don
Jerry
Don
