1970 L46 with AC Heater vacuum control troubleshooting - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    I have a 1970 L46 with AC and have a slow leak in the AC/Heater vacuum control system. I am assuming the entire system should hold vacuum or else the vacuum tank would bleed out completely. Since I may not be able to get to the problem source, has anyone installed a check valve to remedy? Thanks for your suggestions.
    Bill
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
    • 15573
    Re: 1970 L46 with AC Heater vacuum control troubleshooting
    Bill
    Years ago I was told, on the QT, one of our members installed a solenoid in the heater control circuit. This solenoid (it was a FORD product, of all things) was installed under the center console in the area of the heater controls. When the ignition was on the vacuum was open; with ignition off the vacuum was closed. The idea was to minimize leaks through the heater controls so the car could pass PV.
    • William H.
      • January 1, 2006
      • 209
      If a C3 sits for a few days or longer, will it hold vacuum in the tank or eventually bleed out?
      Bill Hyndman
        • 15573
        The vacuum will eventually bleed out. Most of us would be ecstatic if the system held vacuum over night. If my memory is right the PV standard is 3 to 5 minutes.
