Re: F41 strut rod bracket
All------
One more thing on this subject: some folks somehow think that the shock mount shafts for F-41/FE-7 just must be "heavy duty" and otherwise more "special" than the "lowly" standard suspension shafts. That's not the case, at all, though. So, why are the shaft sets different? Well, it's because the F-41/FE-7 rear shock tubes were a larger OD than standard suspension shocks. So, the engineers wanted to ensure a safe clearance from the trailing arm. That's why the shock mount shaft sets were different. Actually, the HD suspension shafts could have been used for both HD and standard suspension and, in later SERVICE, that's exactly what GM did.
All------
