Gm part number for a 1969 rag joint non tilt car - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 799
    Can some one tell me the GM part number for the rag joint on a Dec 1969 built car . Also were they used on other GM cars ?
    Thanks Bob
  • Tom B.
    • March 1, 1978
    • 720
    Re: Gm part number for a 1969 rag joint non tilt car
    Parts manual dated 10/72 calls for 7813351 for 69-71. It later changed to 7818568 listed as 69-81 in both my 9/75 and 3/83 manual. Not sure about usage in other lines but more than likely.
    Tom
    • Bob W.
      • December 1, 1977
      • 799
      Tom, Thanks for your quick reply, these may be helpful in finding a nos joint.
      Thanks again and be safe Bob
      • Tom B.
        • March 1, 1978
        • 720
        Checked passenger car manual and the 568 was also used on;
        1970 full size Chevy, Chevelle, Nova, Camaro except Monte Carlo and power steering
        1971 same except Nova
        1972 Chevelle Camaro
        1973 Chevelle, Camaro Nova exc. p/s
          • 43193
          Thanks Bob
          Bob-------
          Most likely, it was GM #7808553. This coupler has a "flat spot" which keys it to the L1969-82 worm gear shaft.
          Earlier 1969 used coupler GM #7806391. This coupler had no flat spot and could be oriented to any position on the 1963-E1969 style worm gear shaft.
          I believe that by December, 1969 the GM #7808553 was in use in conjunction with the GM #7807759 steering gear. However, it's remotely possible that the earlier style might have been used.
          • Bob W.
            • December 1, 1977
            • 799
            Tom & Joe, Thank you for your help & be safe in these crazy times.
            Bob
              • 43193
              Tom
              Tom------
              GM #7818568 was the last available part number for the L1969-82 coupling. This coupler was used across all GM car and truck lines except Cadillac. It is discontinued without supersession.
              • Owen L.
                • September 30, 1991
                • 838
                This is a good example for using the GM Parts Wiki site to cross reference to other lines.
                Entering the part #7818568 in the query string field yields a number of other GM uses: trucks, Buick, Olds:
                Oftentimes you'll see the supersession info too.
                • Bob W.
                  • December 1, 1977
                  • 799
                  Owen, Thank for your reply and that information.
                  Bob ,Be safe
