Where does the clutch rod spring attach on the firewall? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1387
    Guys,
    I'm installing the clutch pedal stuff on my 69 coupe 350/350 and seems very straightforward except I don't see anywhere on the car that the clutch pedal rod spring can attach to. The AIM and service manual are not helpful. It seems as though the answer should be obvious and easy but I can't see it. I'm hoping I didn't leave something off as stuff was removed during the restoration. Thanks for your help.
    Mike
  • Michael L.
    • December 15, 2006
    • 1387
    Re: Where does the clutch rod spring attach on the firewall?
    Nevermind. Just discovered its on the steering column mounting plate. Steering column isn't in yet so didn't see it.
