Failure of Inside Door Release Mechanism (C2) - NCRS Discussion Boards
  • Russ T.
    • May 31, 1989
    • 113
    I can no longer open either door from the inside of my 1964 convertible
    due to wear and age of the door latch mechanism. I have to reach outside the car and
    press the outer handle to release the door.
    I pulled out both latches and will need get a welder to add a small braze to the lever
    that will allow the locking tooth to clear the striker sprag.
    My problem is that I need to know what metal these latches are made of, so I can buy the correct brazing rods.
    Are they made out of mild steel? Any information is appreciated.
    Russ Trotter
    NCRS #15044
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Failure of Inside Door Release Mechanism (C2)
    I've been welding a bead using my mig welder so they gotta be mild steel. mike
    • Richard G.
      • July 31, 1984
      • 1715
      While the locks are out confirm the staked rivets are not loose.
      It could allow the pawl to slip between the frame and the pivot (sometimes)
      A good peening was all that was required to repair it.
      This was different issue as it only affected the outer door handle release.
      Mine went loose two day before a chapter meet.
      I had to pull the door apart when I should have been attending to other things.
      Take Care.
      Rick
      • Mark H.
        • November 1, 1976
        • 120
        Mike, I may need to do this. But I'm not sure which lever and where to weld a small bead. Any chance to post an image or drawing? Thanks.
        • Mike M.
          • May 31, 1974
          • 8365
          don't have any c2 latch mechanisms to photo for you. send me your latches and I'll repair them, on the cuff. 12500 mason rd cumberland md 21502. will have them back in mail to you same day I receive them. mike
          • Bill M.
            • 1317
            The world needs more people like you Mike.
            • Russ T.
              • May 31, 1989
              • 113
              Mike, could I also take advantage of your good nature and get you to weld a pair of latch mechanisms for me?
              Russ Trotter
              NCRS #15044
              • Mike M.
                • May 31, 1974
                • 8365
                sure. send them . mike
                • Mike M.
                  • May 31, 1974
                  • 8365
                  Russ: u have a PM. mike mccagh
                  • Mike M.
                    • May 31, 1974
                    • 8365
                    russ: did you receive the latches via UPS? mike
                    • Mark H.
                      • November 1, 1976
                      • 120
                      Hi Mike. Received my original latch back from you yesterday. Installed it and it works like new. It pays to keep one's original parts. The repro latch I bought would open the door form the in- and outside, but would not unlock with the key. Many thanks Mike!
