C1 Manual transmission clutch cover finish - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 474
    Hi all, can someone describe the finish on the inspection cover on the bell housing where the starter bolts on is. I believe it would be painted the same as the engine color. Then there is the lower bottom clutch underpan cover. Not sure if but was on during the paint process or was painted Black and installed after painting of the engine.
    Sheldon
  • Bruce W.
    • June 30, 1997
    • 358
    Re: C1 Manual transmission clutch cover finish
    Sheldon, yes both red same as engine color. Bruce
