I'm having some difficulty obtaining motor mounts for my '72. I believe the common part interchange # is 2285. The first pair (Westar) from Rock Auto were too narrow to fit over the frame horns. The second set (Anchor brand) from a local Car Quest Auto Parts store are a bit sloppy with 3/16-1/4" gap to fill. My originals (I believe) seem to be a nice slip-fit but both have a big crack in the rubber circumference where it meets the larger plate so I don't want to reuse them.
Are the larger-gap-than-necessary fine to use as is? Should I use flat washers to fill the gap? Should I continue looking for a better fitting pair?
