Hi Everyone,
69 BB L68 P/S & A/C.
Still working through pulleys and belts. I'm having trouble with the Power Steering pump alignment and subsequently the fitment of the Alternator. Today i started to adjust the new belts, but when i got to tensioning the Power Steering belt the pump moved backward towards the block. It also came into contact with the idler pulley (see pics attached). it happened when i tightened the adjusting bracket bolt.
My thoughts are the brackets could be wrong?
The adjusting brace mount needs a spacer of some sort between the pump and bracket (not shown in the AIM)?
Does the pump look correct, I can't see the P/N but it appears to have an angled reservoir?
Also, after test fitting the alternator it fitted hard against the rocker cover with very little adjustment and looks like it could be linked to the P/S fitment. Any help would be very much appreciated as i want to make sure this is final part all fits correctly before installing the radiator an shroud.
Cheers
Grahame
Cheers
Grahame
