69 - Rear Suspension Reinstall Sequence - NCRS Discussion Boards
  • Jonathan S.
    • February 20, 2009
    • 65
    Re: 69 - Rear Suspension Reinstall Sequence
    Originally posted by Jonathan Spivey (50108)
    Michael,
    The car is lifting because you have reached the peak of the leaf spring flexibility based on the point of lift. You need to lift the leaf spring as close as you can get to end with obstructing your ability to install the cushion/washer/castle nut. This will allow you to flatten the spring as much as possible.
    Just realized that should have been "without" obstructing your ability to install the cushion/washer/castle nut.
    • Michael C.
      • January 9, 2013
      • 328
