Is White Post Restorations still the go to place for sleeving a master cylinder?
who to sleeve a master cylinder?
- Top
- Top
Re: who to sleeve a master cylinder?
Try ---->https://brakeandequipment.com/ They have done two 63 MC for me as well as some wheel cylinders. I'm happy with results and price.
- Top
Dick Whittington- Top
Dick------
I agree. I was not implying that brass was inferior.
As far as material goes, even cast iron would not be a wear problem, at all. It's that water that gets into the system that causes the problems. If the cars had silicone fluid from the beginning there probably wouldn't be a sleeved caliper or master cylinder out there.In Appreciation of John Hinckley- Top
If they had silicone in them in humid areas H2O would still be a problem. Silicone, as you know is not hydroscopic, but moisture still gets in the system. It forms little pockets that may gather in the M/C, lines or calipers and basically never move, creating corrosion in limited, but still problematic areas. I believe it is the reason the military, who BTW uses silicone in all their hydraulic brake systems, flush the braking systems annually to prevent this from happening.Dick------
As far as material goes, even cast iron would not be a wear problem, at all. It's that water that gets into the system that causes the problems. If the cars had silicone fluid from the beginning there probably wouldn't be a sleeved caliper or master cylinder out there.Dick Whittington- Top
Dick,If they had silicone in them in humid areas H2O would still be a problem. Silicon, as you know is not hydroscopic, but moisture still gets in the system. It forms little pockets that may gather in the M/C, lines or calipers and basically never move, creating corrosion in limited, but still problematic areas. I believe it is the reason the military, who BTW uses silicone in all their hydraulic brake systems, flush the braking systems annually to prevent this from happening.
How does moisture get into the system if the fluid is not hygroscopic? Hydroscopic is not the word you want -- look it up.Terry- Top
I'm sure White Post can do acceptable work, but on two separate occasions I sent them a complete set of four wheel cylinders to be sleeved. On each occasion I had to return at least one cylinder to be reworked. I have since switched to Apple Hydraulics and have had zero problems. http://www.applehydraulics.com/- Top
Thus last week Richard Fortier told me he is no longer able to resleeve brake master cylinders. The guy who did the resleeving for Richard is no longer able to do that work and he was the only person Richard used.
Gary- Top
