Compressor Shield - NCRS Discussion Boards
Compressor Shield
  • Harry S.
    • July 31, 2002
    • 5258
    Compressor Shield
    Has anyone successfully mounted one of these on a 63 with A/C. No matter how much I trim it, the hood still hits it and now with the trim it hits the pulley. The compressor in a 63 sits higher due to the one year only compressor bracket. Everything in the car is original.
  • Gary J.
    • April 1, 1980
    • 1229
    Re: Compressor Shield
    Harry, has the compressor been rebuilt, is it throwing oil?
    • Peter H.
      • April 1, 1980
      • 223
      Hi Harry. Would An Adhesive Backed Foil Pad Do The Trick ?.Do You Just Want Something Removable ? Peter
      • Domenic T.
        • January 29, 2010
        • 2452
        Harry,
        It's OK to say I did it a few years ago. Gary, now your both on the same page. I still think it's the new over packed pulley bearings that come out of China. Found a few that melted the grease because of the heat generated by solid packing of grease which causes hydraulic heat. About a spoon full behind the bearing, not to mention what came out the front. Maybe cheap grease! I'll take care of them for both of you. Gary, I think Harry said he is not loosing pressure.
        Gets hard having to stand behind parts. Have to take all ceramic seals apart and replace the black flattened O-ring with a new lubed green HNBR
        O-ring that is dipped in oil. Found distorted O-rings in all the new seals.
        Dom
        • Harry S.
          • July 31, 2002
          • 5258
          Originally posted by Domenic Tallarita (51287)
          Harry,
          Dom
          Dom, it's grease not oil. Just trying to control the spread.
          • Domenic T.
            • January 29, 2010
            • 2452
            Harry,
            Thanks, I forget. The bearings that had the oil come out were not damaged when I removed them. I think once the excess is out it stops and all returns to normal.
            Dom
